Is it safe
Old Oct 21, 2008 | 02:21 PM
FirebirdFormula95's Avatar
Default Is it safe
I have an LT1 95 formula with 140,8xx miles on it would it be safe to run a 75-100 wet shot?
Old Oct 21, 2008 | 02:35 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
I always suggest doing a quick compression test to verify that the engine is in good mechanical condition. But you should have no problems running nitrous on your LT1.
You can run up to a 150 shot on a stock bottom end. But you are correct in the fact it is best to start small and go from there. 75 hp is still 75hp.
I would also upgrade the fuel pump as an extra precaution.
Please let me know if you have any other questions,
Ray
Old Oct 22, 2008 | 12:04 AM
Thanks ray i appreciate the help and advice,
Bill
