Will these brackets fit???LOOK!!!!!
Old Oct 27, 2008 | 10:14 PM
WS6 Canada's Avatar
Default Will these brackets fit???LOOK!!!!!
Will the Wilson ProFlow bracket (2 stage) fit with solonoids under the cowl on a 01 trans am (ram air hood) with the Vic JR and the fuel rails???
http://www.wilsonmanifolds.com/shop/...ct_images&p=58
http://www.wilsonmanifolds.com/shop/...ct_images&p=24
Just the bracket NOT the plate!!!!!!!!!!
Please let me know what you think
thanks
CW
Old Oct 27, 2008 | 10:24 PM
allmotor's Avatar
You have an elbow on top of the intake, or a 4 barrel throttle body?
Old Oct 28, 2008 | 06:02 AM
WS6 Canada's Avatar
sheetmetel elbow from intakelbows.com
Old Oct 28, 2008 | 06:57 AM
allmotor's Avatar
you should be fine then. As far as the solenoids clearing the hood/dash when mounted on the plate, you'll be fine. The elbow will be the highest point of the setup. You have no issues with that elbow you have clearing? I have one from edelbrok but its the low profile one.
Old Oct 28, 2008 | 09:30 AM
Nick@HSW's Avatar
You might need to extend the cut on the cowl to include the solenoid.
When we put the manifold in mike's we had to trim the cowl a little to fit them in.
Old Oct 28, 2008 | 09:44 AM
allmotor's Avatar
I think the only clearance issue will be with the elbow, not the solenoids on the bracket. That's why I picked up a low profile elbow
Old Oct 28, 2008 | 10:06 AM
jmill96Z's Avatar
I don't think it's gonna fit with the fuel rails. I run the edlebrock bracket, and it wouldn't fit sideways. I had to go front to back and bend the rear bracket down a little fit under the cowl.
