race gas in dedicated or not?
Old Oct 28, 2008 | 08:01 PM
allmotor's Avatar
Originally Posted by KeithBerryZ06
Would c16 make a big difference in the dedicated?
Yes. Make sure you have it tuned or have your timing tuner pulling the right amount of timing.
Old Oct 29, 2008 | 09:33 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
We suggest running C16 in all of our dedicateds.....no issue with the o2 sensors as long as you have unleaded in the main tank.
Old Oct 29, 2008 | 09:47 AM
KeithBerryZ06's Avatar
C16 in the dedicated and 109 unleaded in the main on a 250 shot? Any info on Vp's Q23?
Old Oct 29, 2008 | 09:53 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
I have not used that fuel and also couldn't find it on VP's website.
Old Oct 29, 2008 | 10:03 AM
It's under the leaded fuels.
I don't where I got the Q23 from. Its C23. My bad.
C23
Recommended for ultimate performance in nitrous oxide applications with CRs up to 18:1. Used in Sport Compact, ADRL Pro Mod and large 800 CI IHRA-style drag race engines.
* Color: Blue
* Motor Octane 120+
* Specific Gravity: .713 at 60° F
Old Oct 29, 2008 | 10:12 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
I saw that one...I was looking for Q23.
I see no benefit to running C23 over C16 in the dedicated.
Unless you decide to start spraying alot more than 250HP
Old Oct 29, 2008 | 10:17 AM
allmotor's Avatar
There was a camaro at the Radial Tire Championship with a bigblock and 4 dry direct port kits. 2 on the outside like that, and 2 on the inside.
Old Oct 29, 2008 | 10:28 AM
So C16 in the dedicated and 109 unleaded or C16 in the main fuel tank?
Old Oct 29, 2008 | 10:33 AM
allmotor's Avatar
C16 in dedicated. UNLEADED IN MAIN TANK (leaded in main tank will damage your sensors)
Old Oct 29, 2008 | 10:36 AM
Thanks for the info!
Old Oct 29, 2008 | 10:38 AM
allmotor's Avatar
Old Oct 29, 2008 | 11:17 AM
  #32
Ray@Nitrous Outlet
Guest
Posts: n/a
So C16 in the dedicated and 109 unleaded in the main fuel tank?
Old Oct 29, 2008 | 12:33 PM
  #33
I asked the same question to VP and below is their reply. Thanks for all your help guys!
Hello, Keith Berry
You submitted:
I am going to a single stage 250 shot of nitrous. I have a dedicated fuel tank for the nitrous. What would be the best fuel to run in my main tank and what would be the best fuel to run in my nitrous dedicated tank?
VP Racing Fuels Reply:
If you are happy with the MS-109, keep using it. You are right on the border between it and moving up to the VP-113. Both fuels have the same oxygen content for extra power, but the VP-113 has a 108 motor octane to allow for more timing and compression. I would use the C-16 in your dedicated nitrous tank.
Old Oct 29, 2008 | 12:41 PM
  #34
allmotor's Avatar
Hello, Keith Berry
You submitted:
What telepathy is this?? They knoes you has MS-109?
Old Oct 29, 2008 | 02:08 PM
  #35
I can't reveal all my special powers.
Old Oct 29, 2008 | 07:50 PM
  #36
firefighting1101's Avatar
run e85 in it! it burn more efficiently and still has a 105-107 octane
Old Oct 30, 2008 | 12:00 PM
  #37
1BADAIR's Avatar
I run c16 in the standalone. sometimes 103 in the car
Old Oct 30, 2008 | 03:42 PM
  #38
dawiz's Avatar
tuned the car last night.
110 in the dedicated. 93 in the tank.nitro daves wet kit
150 pill in the n20 side and .035 jet in the fuel side.
with the .038 jet we were at 10.0 a/f so we swapped to the .035 and went to 11.20.
went from 440 on motor (no torque cause the tach wasnt reading right. acutally it showed like 1800 rwtq.LOL!)
550/550 on the squeeze.
only had to take 1 degree of timing out so the na tune isnt giving anything up at all.
car feels great!
Old Oct 30, 2008 | 03:57 PM
  #39
allmotor's Avatar
Originally Posted by dawiz
440hp / 1800 rwtq
omg you sure it was 93 and not diesel??? LOL
sounds good man
Old Oct 30, 2008 | 07:26 PM
  #40
Loudmouth LS1's Avatar
car feels great!
Sweet Scott, i'm sure you'll have fun with it!
