Which progessive controller for an M6
Old Nov 2, 2008 | 04:29 PM
buzz12586's Avatar
Default Which progessive controller for an M6
I plan on spraying a 150-200 shot on my car and I would like to bring it in slowly instead of all at once. Probably a 50 shot in 1st gear and then adding the rest in 2nd gear. Whats the best progressive controller to do this with?
Old Nov 3, 2008 | 07:53 AM
JoeyGC5's Avatar
You could probably get an FJO mini to do this. But you'll need to add some extra switchs to configure the first stage and second stage outputs to work. ie a first gear switch for stage 2 to operate first and then stage two is locked out and stage 1 works in any other gear.
Old Nov 3, 2008 | 09:55 AM
Chris@NitroDaves
Guest
Posts: n/a
Are you wanting to do this via 2 stages or 1 single stage?
-Chris
Old Nov 3, 2008 | 09:58 AM
stevegrizzle's Avatar
Just progress in 25% over .2-.4 sec and it will work good for all of your shifts and save your clutch. FJO mini dumdumdum! (plus they are like $200!)
Old Nov 3, 2008 | 10:04 AM
buzz12586's Avatar
I was planning on doing it with a single stage with either a nozzle or plate system. I think it would be cheaper than buying another set of solenoids and a nozzle/plate correct?
Old Nov 3, 2008 | 10:45 AM
Chris@NitroDaves
Guest
Posts: n/a
You are correct.
If you will carrying a laptop with you everywhere the car is then i'd suggest the FJO mini progressive controller http://www.nitrodaves.com/catalog/pr...product_id=952. I believe it will suite your needs to a T. If you aren't going to have a laptop with you then i suggest getting the NOS mini http://www.nitrodaves.com/catalog/pr...roduct_id=1539 because it comes with a handheld box to make programing changes.
Got both instock and ready to go
-Chris
Old Nov 3, 2008 | 11:51 AM
Quick96ss's Avatar
I run the Nos Launcher on my M6 and love it. It is alittle bit more money though!!
Old Nov 3, 2008 | 01:23 PM
Originally Posted by Chris@NitroDaves
You are correct.
-Chris
The laptop is only need to make changes though......so why would you need to carry it "every where the car goes"?
You only need a laptop if you plan on changing anything correct?
Old Nov 3, 2008 | 02:53 PM
Chris@NitroDaves
Guest
Posts: n/a
You never know when the next race is.....
-Chris
Old Nov 3, 2008 | 09:49 PM
DiabloFormula's Avatar
Get the NOS Mini, easy to use, cheap and you don't need a laptop....ever.
Old Nov 4, 2008 | 09:17 AM
-Chris
But it can function w/o the laptop correct? You just need the laptop to set it up and change settings right?
I am not trying to be a dick, I just thought that........I don't own one yet, want to make sure.......
