Tach signal ?????
Old Nov 5, 2008 | 02:36 PM
1969mach1's Avatar
Default Tach signal ?????
Nitrous window switch.....
2001 Z28 A4
Is the tach signal input the #10 pin (white wire on the RED plug of the PCM)?
Installing a Summit window switch #SUM-830452
http://store.summitracing.com/partde...5&autoview=sku
I also would use the LOW voltage wire on the window switch, RIGHT???
http://static.summitracing.com/globa...sum-830452.pdf
Old Nov 5, 2008 | 02:45 PM
2002camaroSS's Avatar
I cant remember off the top of my head but I went to the dealship and had them print me a diagram out of all the pins that said what was what.
Old Nov 5, 2008 | 04:23 PM
ShiznityZ28's Avatar
yes # 10 white .
Old Nov 5, 2008 | 04:24 PM
KH504's Avatar
Thats it #10 white I just did mine
Old Nov 5, 2008 | 04:27 PM
1969mach1's Avatar
very cool, thanks
