Nitrous and Wideband
Using the narrow band sensors is ok, but keep in mind the narrowband sensors are designed to tell you whether its at 14.7ish (and it good for that), its lean, or its rich. Just how rich or lean is really just a wag with the narrowband. When Spraying the general opion is 11.5-12.0 is the target AFR. That being said, what is that on Narrowband? The sensor is set up for 14.7 so your looking for a rich indication, but its really a just a guess and an indication that its rich...just how rich though???
With the Wideband, you pretty much know where your at AFR wise so your tuning is more accurate (providing its set up correctly).
Us 99-00 guys have 26# injectors stock, the other years have 28#
On Dry shots the injectors are pretty important. Above a 50 shot I was lean (and I knew this because the 75 shot was tested while running a wideband)...Added 42#, modified the tune to reflect the new injectors and AFR is now good.
If your using your NB on the 100 shot, and it shows 14.7...your lean, and likey the injectors/nozzle position/ or both, need to be re-evaluated.
