Who likes N20 dynos????????
Old Nov 12, 2008 | 12:46 AM
AZNastyz06's Avatar
i just installed a harris wet shot kit on my z06. also bought the accesorie complete kit and installed a racemetric fuel pump and 30lb ford red top inhjectors.
Old Nov 12, 2008 | 06:08 AM
Mike@HSW's Avatar
did you have a full bottle and adequate pressure?
Old Nov 12, 2008 | 08:21 AM
gator's 99TA's Avatar
Originally Posted by stevegrizzle
The bottle pressure falling off is the cause of the fatness up top. I am going to tighten up the PE tables and hopefully compensate for that.
a dyno with that kind of power should only be activating the nitrous for a few seconds. you shouldnt have a drop in pressure over that short time span unless you were very low on nitrous volume.
Old Nov 12, 2008 | 10:22 AM
stevegrizzle's Avatar
It was a full bottle, 950 psi.....Like I said I need to work on the 5500-6k fueling.....you can see in the na run it goes a little rich up top too.
Old Nov 12, 2008 | 10:44 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
It would be best to stabilize the NA A/F ratio before working on the nitrous curve.
Old Nov 12, 2008 | 10:45 AM
camar0corey's Avatar
Where did you dyno at? I think you are close by if I remember right.
Old Nov 12, 2008 | 10:48 AM
Race Related.......
Old Nov 12, 2008 | 01:52 PM
1.8t's Avatar
Why not just adjust your maf curve?
Old Nov 12, 2008 | 03:22 PM
It is setup for SD.
