How much HP can a 2ft 3AN Nitrous line flow?
Old Sep 20, 2003 | 06:07 PM
Aidan's Avatar
Default How much HP can a 2ft 3AN Nitrous line flow?
I have a NX Wet EFI nitrous kit, single fogger.
Im upgrading to a 6an main 16 ft feed line for my nitrous because i cant get a full 200 rwhp out of my 4an feed line.
With the 6an line running to the large solenoid, will the 2ft 3AN lines from the solenoid to the fogger flow 200-250 rwhp ???
Old Feb 2, 2014 | 10:47 PM
Prowler's Avatar
Originally Posted by Aidan
i cant get a full 200 rwhp out of my 250 hp system.
With the 4an line running to the large solenoid, will the 2ft 3AN lines from the solenoid to the fogger flow 200-250 rwhp ???
I wonder this same thing.
Old Feb 3, 2014 | 06:55 AM
brandon6.0's Avatar
I doubt it. 4an at least after solenoids.
Old Feb 3, 2014 | 11:02 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
The 4AN feed line isn't the restriction. 4AN will do 300hp all day. The 3AN is only good for 150 on the nitrous side. You will need a 10124 SHO hose, and a 16109 fitting, this replaces the outlet side of the nitrous solenoid with 4AN stuff, alllowing you to run more HP.
-Garrett
