Spark plug inspection
Old Nov 17, 2008 | 07:35 PM
OLDSCHOOL85's Avatar
Default Spark plug inspection
After a nitrous pass - Should I pulled all the plugs or just one or two?
Is their one cylinder than runs leaner than others on a ls1 engine? or which cylinder is most common for problems?
Old Nov 17, 2008 | 07:53 PM
Travis99LS1's Avatar
im not an expert on this but i want to say that number 7 tends to go lean on our motors..
Old Nov 17, 2008 | 08:28 PM
TurboAv's Avatar
I heard the back two cylinders run hotter, but especially #7. However if you are just initially tuning a kit I would pull all eight just to be sure and after that only pull the back two.
Old Nov 17, 2008 | 08:30 PM
ShiznityZ28's Avatar
On a stock PCm theres not much you can do to correct it. tune off of 7 and 8 but use 1 and 2 for refrence for diffrences in the motor. but its aways good to look at all 8 to make sure everything is good.
