HSW Interface with big cam and tune???
Old Nov 17, 2008 | 08:21 PM
TurboAv's Avatar
Default HSW Interface with big cam and tune???
Since I have determined I should keep my FAST intake and just add a plate kit to it I now find myself comtemplating dry vs wet. If I go wet I was going to use a standalone and if I go dry I'll need bigger injectors and a fuel pump. The cost difference isn't really that different for either system. I also plan on using a NANO system as well for either.
The HSW Interface and Micro Edge controller interests me because I can run a full timing NA tune and then the controller will pull timing when it's activated and adjust the fuel. The Edge controller also has a feature that will shut the nitrous down on a lean condition and a overly rich condition. You can even specify the A/F ratio and how long it must be in for in .1 sec increments to shut things down. Regardless of dry or wet I am going to use the Micro Edge just for that feature alone.
What do you all think?
Old Nov 18, 2008 | 07:57 AM
Nick@HSW's Avatar
I'd give my opinion but I think I'm just slightly biased. Do some searching, plenty of people running the Interface/MicroEDGE combo that are pleased with the results. If you have any questions just ask. Thanks.
Nick
Old Nov 18, 2008 | 11:26 AM
jetlag's Avatar
The Interface is working great on my car...
Old Nov 18, 2008 | 11:32 AM
TurboAv's Avatar
Do you have a big cam and aftermarket tune? Do you do your own tuning or have someone do it for you? I'm thinking I may need to invest in EFI Live or HP Tuners to really get the adjustability I want.
Old Nov 18, 2008 | 04:26 PM
bad6as's Avatar
mines great now
Old Nov 21, 2008 | 07:02 AM
Mike@HSW's Avatar
We did test this same combination on my car which does have a big cam in it. Worked like a charm, picked up 108 rwhp on a 100 shot with A/F at a conservative 11.5. When we were designing the MicroEdge all i could think about was how well it will work with the interface on a dry plate.
Old Nov 21, 2008 | 12:47 PM
TurboAv's Avatar
One of the local Vette guys is getting his C5 Z06 tuned today with your 100hp dry nozzle. He has a cam in his car, so I'll talk with my tuner in the next couple of days and see how he liked it. If he gives it a thumbs up I'll be getting your dry plate system and Micro Edge.
Old Nov 21, 2008 | 12:55 PM
Mike@HSW's Avatar
is he running a dry plate or a pre-maf nozzle?
Old Nov 22, 2008 | 07:15 PM
TurboAv's Avatar
It looked to be a post maf nozzle to me. Its about 3"-4" in front of the throttle body. They ended up having the wrong A-pillar pod, so the tune got pushed off until this Tuesday. Hopefully it goes good. I'm really interested in doing a dry system.
With the cam and mods in my sig what size injectors would I need to add a max of 300hp to the wheels dry? I was thinking of the 80lb/hr Racetronix, but I don't know how to do the calculations to be sure.
Edit: I'm going to start with your plate at about 150-200, then once the motors forged I'll use the plate for the first stage of around 100 and add a direct port for the 2nd stage of 250-350.
Old Nov 22, 2008 | 07:25 PM
Mike@HSW's Avatar
60 lb injectors will take you pretty far, the racetronix 79lb/hr should certainly cover you to those kinds of numbers.
http://www.racetronix.com/01D129xFM.html
Old Nov 22, 2008 | 07:28 PM
Mike@HSW's Avatar
that sounds like a good plan. Thats pretty much what i run.
Old Nov 26, 2008 | 10:24 AM
Superman09's Avatar
LS1Tech Sponsor
^^^ that is beautiful!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 26, 2008 | 04:53 PM
Nick@HSW's Avatar
Thanks,
Mike put some hard work into smoothing the entire intake prior to the powder coating.
Nick
