dyno differences between 92 octane vs 114?
Old Sep 22, 2003 | 06:33 PM
Assassin's Avatar
Default dyno differences between 92 octane vs 114?
has anybody done a dyno test with the n2o useing 92 pump then 114 race?, I'm trying to figure if it'll make a big difference and how much time it'll cut off the e.t.
Old Sep 22, 2003 | 06:52 PM
Colonel's Avatar
Default Re: dyno differences between 92 octane vs 114?
If you're not getting detonation or pre-ignition with 92 octane then you won't see more power just by going to a higher octane (all else being equal.) Now if we up the nitrous to go with our extra octane, well that's a different story.
Old Sep 22, 2003 | 10:13 PM
Loader's Avatar
Exactly.
Higher octane fuel has a lower BTU count (basically, the amount of engery released when burned). So, with nothing else changed, use of higher octane fuel won't produce more power by itself - you may actually produce LESS power.
What higher octane fuel allows you to do is increase whatever you are playing with. You can increase your timing, increase your nitrous, increase your boost level, whatever - all because the higher octane rating means it is harder to start the burn (less prone to detonation) not more volatile as many people assume.
Actually, if you ran 89 octane fuel and optimized for that, then added 120 airplane fuel and changed nothing else, you'd actually have a power loss you'd notice.
Old Sep 23, 2003 | 01:54 AM
Assassin's Avatar
damn..., great answer, thanks, maybe you can help with this one? https://ls1tech.com/threads/showflat...31&fpart=1
