HSW plate and custom smooth bellow
Old Dec 19, 2008 | 07:28 PM
jetlag's Avatar
Default HSW plate and custom smooth bellow
I tried to cut up my stock bellow but it just wouldn't work...so check out my custom smooth bellow and dry plate
Before - ewww ugly
After - bling bling
Old Dec 19, 2008 | 07:33 PM
zracer323's Avatar
Looks good...what did you use to make it?
Old Dec 19, 2008 | 07:34 PM
jetlag's Avatar
A rubber coupling thing from Lowe's. It's a popular and cheap alternative to the SLP bellow...which I would have had to cut up also...but spend $60 compared to $8.
Old Dec 19, 2008 | 09:04 PM
jmill96Z's Avatar
Nothing like a little Fernco.
Old Dec 19, 2008 | 09:37 PM
ExceSSive's Avatar
I got one from intakehoses... just google it and you will find it. It cost like $20 and looks a little better than the Fernco. I had the Fernco for a while until I found that website. Looks good though. I can't wait until I get some extra funds for nitrous kit.
Old Dec 19, 2008 | 09:52 PM
black01_WS6's Avatar
why is there no line on the other side of the plate? if it is their dry plate- which is the same as their wet plate you should have it hooked up on both sides for even distribution.
so a 035 jet on both sides is a 75 shot total.
Old Dec 19, 2008 | 09:55 PM
jetlag's Avatar
It is a dry kit... and I plan on capping the other side. If the car did fine on one nozzle before, then it should do fine on one port this time with several holes spraying on the plate.
I think it would be silly and redundant to T it off to both ports....no need to do it on a wet kit, so why do it on this.
Old Dec 20, 2008 | 01:28 AM
myfast70's Avatar
Each side of the plate controls a ring in the center of the plate. There are two rings inside the plate so distribution is always even!
Old Dec 20, 2008 | 02:01 AM
jetlag's Avatar
Yes..... but all I'm trying to say is....if one nitrous port is good enough in a wet setup..why isn't it good enough for dry???
Old Dec 20, 2008 | 09:45 AM
myfast70's Avatar
That was my thinking too. I didn't know that HSW has you tee off the the nitrous from the solenoid to the plate. They may do it for even better distribution? I'm sure HSW will chime in.
Old Dec 20, 2008 | 01:21 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
It looks better, but you need to get rid of that tape.
Old Dec 20, 2008 | 01:30 PM
kyle99ta's Avatar
Wheres's your WOT switch?
Old Dec 20, 2008 | 02:08 PM
Mike@HSW's Avatar
Its just an option with the dry plate. You can setup the dry plate either way and it will be perfectly fine. The plate has 10 nitrous discharge points, which honestly is plenty. If you T off the noid and go into both sides you will have a total of 20 discharge points. Its nice, but depending on how much you are spraying its probably overkill and the 10 discharges will be more then enough.
Old Dec 20, 2008 | 05:55 PM
jetlag's Avatar
Yeah...that tape is kind of important right now.... Before I had the Interface, I swiss-cheesed my lid trying to find a good spot for the nozzle. Every location went lean. Interface = awesome
Mechanical WOT switches are obsolete.
Old Mar 6, 2009 | 07:56 PM
jetlag's Avatar
New pic.
I got a big boy HSW solenoid and SJM ABS delete kit...
Hah, it seems my lid gets worse every day. When swapping injectors, I spilled a little bit of gas on the SLP lettering. It came off quick..
Here is a link to a bigger version...
http://i135.photobucket.com/albums/q...bigversion.jpg
