Do open cutouts affect A/F ratio?
EX 1 : F-body with a single cutout in I=pipe before axle..no change
EX 2 : any car we have seen which has them near or directly off the headers did change the A/F a 1/2 point or more leaner
WBO2 readings aside, a cutout will usually lean out the burn in the chamber.
How much depends on how much backpressure you have before opening the cutout. If you are running near the lean limit corked up, then yes it might cause you a problem.
In the "old days" guys had to jet up the carb & pump shot for running open exhaust.
