window switch question
Old Sep 29, 2003 | 03:18 PM
jamescb77's Avatar
Default window switch question
What is the difference between the normal window switch and the modified one for ls1's? Does the normal one work fine whats the deal there? thanks jamescb77
Old Sep 30, 2003 | 05:08 PM
y2kss1603's Avatar
Default Re: window switch question
If mean a new MSD from a retailer,then it will not work on an LS1 unless you send it back to MSD and have it modified for the LS1 signal. Which, I believe is a 5 volt signal. Additionally, you will also be required to cut the two loops as in a 4 cylinder application. Other than that, they work great!
Hope this helps,
Eric
Old Sep 30, 2003 | 10:46 PM
koolrayz's Avatar
I just cut the loops and called it good. Many others have done the same and not had any problems.
