No2 for medium grip car....
Old Dec 30, 2008 | 01:16 PM
deuce_454's Avatar
Default No2 for medium grip car....
Im installing a H/C/I combo of TEA ls6 stg2/226-232-.609/.604-111LS+2 and vic jr. w 4150 style TB (EFI) on my 2002 LS1, car is a 79 malibu with built A4 and a 3.73 moser 12 bolt...
im running BFG 285's (not DRīs) and traction in first is acceptable but not super...
what i would like to accomplist is a No2 setup that will come on progressivly and smoothly but still add power.. perhaps from 2ns gear or whenever i find out i can spray...
i dont want a million ***** and switches, just one "arm" switch... and the rest should just work automatically when i floor it.. how do i do this best???
are there systems that can adjust different powerlevels without changing jets??? ramp up ?? since its a 4150 style TB im thinking that a plate will be the ticket.... but what electronics do i need??
could i increase the hit and power with the turn of a ****/throwing a switch when i throw on DRīs??
Old Dec 30, 2008 | 02:52 PM
Chris@NitroDaves
Guest
Posts: n/a
What HP level are you wanting to spray on the car? Also are you worried about hood clearence issues?
For what you are wanting to do I'd suggest the NOS Mini Progressive Controller - http://nitrousoutlet.com/catalog/pro...roduct_id=1539 .
Unfortunately there is no system out there that you can adjust the HP level without changing a jet.
-Chris
Old Dec 30, 2008 | 06:46 PM
deuce_454's Avatar
nice little gadget.... looking arround on your site i figured out that a dual stage system should do the trick.... but it sure adds up
dual stage kit
controller
purge
bottle opener..
and what about timimg retard?? will i have to tune the car to run with nitrous.. or can i trick it somhow... spray meth at the same tome and keep my DD timing tables?? or how do i solve that??
meth and high ochane perhaps
and i would spray 100 to max 200....
Old Dec 31, 2008 | 07:35 PM
white2001s10's Avatar
Ramping up the ignition timing a little slower for launch will soften it up like you want.
Old Jan 2, 2009 | 09:29 AM
Chris@NitroDaves
Guest
Posts: n/a
With what you are wanting to do i'd suggest getting one of these units. Both are good and work very well.
http://www.nitrousoutlet.com/catalog...roduct_id=3467
or
http://www.nitrousoutlet.com/catalog...product_id=965
-Chris
Old Jan 2, 2009 | 12:43 PM
deuce_454's Avatar
wow thay are really neat little systems.. all id need was to replace the idiot light cluster with a controll panel with some innocent looking switches...
