Hsw interface?
Old Jan 2, 2009 | 11:50 PM
dudeman's Avatar
Default Hsw interface?
i have a tnt f2 i just installed on my car. i just got the interface and microedge controller in the mail today. i had my car tuned and found out from the tuner that the timing was set at 32 degrees. my question is will the interface allow me to pull enough timing for a 150 shot. what do i need to set the little switches inside the controller at.
Old Jan 3, 2009 | 01:27 AM
evilbeef54's Avatar
yes, it should work just fine, start by folowwing the HSW instructions and pulling 6* of timing out, are you using any datalogging software to see how your tune is running?
Old Jan 3, 2009 | 07:31 AM
Nick@HSW's Avatar
Just jump over here and they can walk you through it. www.harrisspeedworks.com/support. Fill out a ticket and they can tell you what needs to be set and what doesn't. Just make sure you add all of your vehicle info. Thanks.
Nick
Old Jan 3, 2009 | 09:16 AM
dudeman's Avatar
no datalogging software. what do i need to set the little switches at to pull 6 degrees?
Old Jan 3, 2009 | 09:18 AM
dudeman's Avatar
Nick
filled one out last night. what al info do i need to give. i i gave year make model engine trans, mods and how much i want to spray. should that work? thanks!!!
Old Jan 3, 2009 | 10:42 AM
bad6as's Avatar
stock you are only gonna be able to pull 3. unless you go in the tune and pick the iat table and change how much it pulls
Old Jan 3, 2009 | 11:37 AM
dudeman's Avatar
when you say go into the tune, you are saying with hp tuners?
Old Jan 3, 2009 | 01:30 PM
bad6as's Avatar
yes then you can change how much timing is pulled depending on the iat temp
Old Jan 3, 2009 | 05:21 PM
dudeman's Avatar
if it was the timing was advanced with hp tuners would the interface still pull 3-4 degrees or would it pull more?
Old Jan 3, 2009 | 07:07 PM
evilbeef54's Avatar
unless they messed with the IAT tables it will still pull the same ammount as the instructions say
