LT1 (wet) nozzle location??
Old Jan 5, 2009 | 12:11 AM
LM97Z's Avatar
Default LT1 (wet) nozzle location??
Would like to see some pix of where you have your Nozzle located, i'm still useing the stock elbow, running hard lines, does this location/position look fine?
Old Jan 5, 2009 | 12:52 AM
porksoda's Avatar
I'd go a little further away. I believe they say at least 6" away from the TB for better distribution. I have mine on the other side of the IAT so it's basically as far as it can be while still being a straight shot into the intake.
Old Jan 5, 2009 | 01:07 AM
LM97Z's Avatar
That makes sence, but in that area its on a curve, i would still want the Nozzle to be as straight as possible on the curve like it is now, i did read where they said between 2-6" away from TB.
Old Jan 5, 2009 | 01:23 AM
porksoda's Avatar
I didn't put it in the curve. Right before it starts is where mine is.
Old Jan 5, 2009 | 08:30 AM
z28rob18's Avatar
i dont have a pic but mine is right under the elbow we made it come up underneath the elbow
Old Jan 5, 2009 | 12:09 PM
LS1 SPEED's Avatar
I think your nozzle placement will be fine. The TNT kit had nozzles in the plate and people run them with no issues.
