Bottle Dementions
Old Jan 11, 2009 | 07:19 PM
Y2K WS6's Avatar
Default Bottle Dementions
Hey guys, I'm considering adding a 100 shot of Nitrous after I install my heads and cam. My question really is what are the dementions of a 10, 15 or 20 pound bottle. I'm planning to hide the bottle as much as possible. Everyone who sees my car doesn't need to know it's on funny juice. cops hate it.. and some people just laugh at you.
so. Length, and either circumference or diameter either one will work. My plans/hopes are to either put it in replacement of the spare tire ( but would like to keep the tire you know just in case. middle of nowhere flat tire) or on the drivers side partly behind the plastic cover.
Old Jan 11, 2009 | 07:22 PM
LS1crazy01's Avatar
If your planning on keeping it hidden I would not go bigger then a 10lb bottle. As for Dimensions I dont have them.
Old Jan 11, 2009 | 07:55 PM
Y2K WS6's Avatar
I"m not opposed to doing a little work to hide it. i figure at a 100 shot i'd get around 12-15 passes max of N20 before the bottle ran out.
Old Jan 11, 2009 | 08:18 PM
zracer323's Avatar
10lb bottle - 7" diameter, 20" from bottom of bottle to top of valve
15lb bottle - same diamter but 6-7" longer if i remember correctly
A 15lb bottle will fit in the spare tire well. A quick search should find some pictures of that.
Old Jan 12, 2009 | 08:59 AM
Y2K WS6's Avatar
Thanks! i can mock some up and see what will work.. like i stated i'd like to keep the tire.
also is there a specific angle the bottle has to set at? Thanks!
Old Jan 12, 2009 | 10:10 AM
CHEVYXTREME_00's Avatar
Does anyone know the length and diameter on the 12 Lbs. NOS carbon bottle?
