fuel pumps questions
Old Oct 4, 2003 | 04:16 PM
PlowTown Missile's Avatar
Default fuel pumps questions
What happens when you put a bigger inline pump than the stocker? Does the stock pump slow the flow down? Will it burn up the stock pump or the inline pump? So how does the inline give you more flow than the stock one? The stock one can only put out so much. How about the inline pump and I gut the stock pump and just use it as a pickup? Can you do this?
Old Oct 4, 2003 | 04:52 PM
parish8's Avatar
single digit dreamer
Default Re: fuel pumps questions
a pumps output is directly related to the presure it has to pump at. right now the stock pump has to push 60psi, if you drop that to 5psi or whatever it takes to get the fuel to the inline the volume goes way up. with something like a walbro gs340 you get the full rating of the inline pump. if you went all out and put something like a king sumo in there and left in the intank then it might become a restriction.
