Window switch digram
Old Jan 22, 2009 | 03:54 PM
volcanic2345's Avatar
Default Window switch digram
Anyone have one i search but cant find nothing iam hooking one up with a full throttle switch and purge never hooked one up with a window switch
Old Jan 22, 2009 | 04:12 PM
its a msd window switch and nitro dave wet kit
Old Jan 22, 2009 | 04:20 PM
Nick@HSW's Avatar
http://www.msdignition.com/instructiondownload.aspx
Just type in the part number and it will pull up the instructions for it. Or there should be a wiring sticky at the top of the forum. If you still can't figure it out, shoot me over the part number on the window switch and I can tell you what goes where.
Nick
Old Jan 22, 2009 | 05:22 PM
ok i think i got it but where does the yello and grey wire go on the ls1 engine and the white one also?? part number is pn 8969
Old Jan 22, 2009 | 05:43 PM
Nick@HSW's Avatar
Gray doesn't get used. The yellow will be the ground for the relay. You will have to check with where you got your kit from, but on our systems it hooks to pin 85 on the relay. White wire is your RPM. It depends on what year car it is, but most LS1 cars hook it to pin 10 white wire located on the red connector for the PCM.
Nick
Old Jan 26, 2009 | 11:43 AM
Nick
THANKS!!!
