Track times with 5177?
Old Oct 14, 2003 | 02:32 PM
Berman8or's Avatar
Default Re: Track times with 5177?
Bottle pressure is very important. If you want the best power with the 5177 kit, be sure you pressure is about 1100-1250psi.
My Zex bottle heater has a 900 psi thermostat.
Old Oct 14, 2003 | 03:28 PM
Colonel's Avatar
Is it adjustable in any way? The NX heater is.
Old Oct 14, 2003 | 05:51 PM
B18B1LS1's Avatar
When I dynoed it was with a cut-out, K&N, and the 5177 kit as my only mods. At the time it was hooked up through only one solenoid with one feed line. My bottle pressure was ~1250. My NA dyno was 308/321. The next run on the gas was 454/547 with the stock converter unlocked. I've since added the PT4400 and the dual feed lines and a second stage wet kit. I did spray in 4th because of my 4.30 gears. I didn't want to but it just ended up that way. Bad combo setup on my part I guess.
Jeffrey
Old Oct 14, 2003 | 05:56 PM
4thGENRETARD's Avatar
Jeffrey
On the contrary Jeffrey, You got major cahoonas man. don,t know how much it would last but thats impressive!!!
Thanks for the info, good luck.
Old Oct 14, 2003 | 08:20 PM
99TranTrany's Avatar
Can bottle pressure make really make that much of a difference? 71 HP difference (146-75)
Old Oct 14, 2003 | 09:02 PM
Robert56's Avatar
Bottle pressure can make a very big difference. For example, no heater on a 70* day your pressure will only reach about 750psi, which is not good for best power out-put.Do you know what pressure you were running and how full your bottle was. One more thing, if bottle was low and your heater heats to temp, instead of pressure, you will not reach your 1050 setting like on full bottle.
Old Oct 15, 2003 | 03:13 AM
Berman8or's Avatar
No.
