it is necessary to upgrade ?
Old Feb 8, 2009 | 12:10 PM
PONTIAC SLP's Avatar
Default it is necessary to upgrade ?
hi , i have 2001 WS6 M6 , it between 400-430 RWHP , i'll spray 175HP , it's enough to upgrade the fuel pump only with stock injectors ?
thanks.
Old Feb 8, 2009 | 12:18 PM
TPRDFW's Avatar
yes and yes
Old Feb 8, 2009 | 12:30 PM
Originally Posted by TPRDFW
yes and yes
with stock injectors and walbro 255 fuel pump direct in tank and 175 shoot the tune will be okay and in safe way ?
Old Feb 9, 2009 | 06:25 AM
please guys don't skip me i'm in problem now , i want to tune my car with 175 and i don't know what i do ! if i installed fuel pump without aftermarket injectors the tune will be okay ?
Old Feb 9, 2009 | 06:29 AM
Ryan@RPM-Motorsports's Avatar
If you are on a dry shot, replace your injectors.
If you are using a wet shot, a walbro intake will be fine.
Old Feb 9, 2009 | 06:39 AM
bryan @speedINC recommend me to run with walbro 255 direct in tank is this good for my application ? 175 wet shoot ?
Old Feb 9, 2009 | 06:44 AM
Yes, that will work fine.
Old Feb 9, 2009 | 10:45 AM
thanks a lot
Old Feb 10, 2009 | 06:38 PM
let see new opinions
Old Feb 10, 2009 | 06:41 PM
jmill96Z's Avatar
You should be good with just the 255 pump. It never hurts to know the duty cycle of the stock injectors when you're putting out 425+ on motor. If you have a solid tune with the stockers, you'll be fine with a 255.
Old Feb 10, 2009 | 06:46 PM
thanks a lot , i ordered 255 walbro fuel pump direct in tank , i hope everything will be in safe way for 175HP
Old Feb 10, 2009 | 08:41 PM
Somebody09's Avatar
I simply bought the Racetronix kit...
http://www.racetronix.com/RX-F99-FPKG-2.html
http://www.lonniesperformance.com/fuelsystems.htm, part # RX-F99-GSS340-FPKG-2
Old Feb 10, 2009 | 09:34 PM
Nitro Dave's Nitrous Outlet's Avatar
I would do more than just replace the fuel pump. Replaceing the fuel pump with a walboro does not give you much room if any to grow. I would do the racetronix system. That will give you support up to 650 rear wheel hp. We sell the racetronix system for 249.00. Just about any vendor carries this system.
As to the injectors if your nitrous system is a wet system you do not have to worry about injectors as long as they are good enouigh to support the motor NA.
Dave
Old Feb 11, 2009 | 07:12 AM
john563's Avatar
I think you'll need the hotwire (racetronix)set up not just a pump.
