spray and a vindicator, estimate numbers/track times
My car is a M6 with stock 10 bolt with 373, pacetter LTs, with ORY, and LM1 cat back. It has 853 heads, and i will be installing an ls6, with a ported TB, and a vindicator cam with necessary valve train, and a set of fast 36 LBS injectors. The bottle will have a heater to keep bottle pressure up. As well as a purge and Nitrous outlet window switch And as stated above will be spraying it with a 100 shot. Thanks for your opinions. I am also new to the nitrous world. thanks. i weighed in last year a 3340 LBS with full exhaust, by the way.
