Do i have everything I need?
Old Feb 21, 2009 | 03:48 PM
z28_YOU_HO's Avatar
Default Do i have everything I need?
Ok well i bought the wet single nozzle kit from HSW...So far i have added a Nitrous outlet digital dual window switch, blow down tube and NHRA valve. I also have the hump mount bracket on the way. What else do I need besides plugs??
Im going to be starting on a 100 shot. Am i going to be safe as far a fuel and injectors go?
Car is full bolt ons A4 with a 3500 converter.
Should I dyno to check my A/F before spraying?
Old Feb 21, 2009 | 04:11 PM
Mike@HSW's Avatar
Always verify your A/F ratio with a couple wideband dyno pulls. I would definitely add a nitrous filter and a bottle heater for consistent pressure. fueling and inectors will be fine.
Old Feb 21, 2009 | 04:22 PM
z28_YOU_HO's Avatar
Nitrous filter will be next. Im going to try to find a used automatic bottle heater.
If i decide to bump up the jets to a 150 what am I lookin at as far as upgrades on fueling?
Old Feb 21, 2009 | 04:31 PM
Mike@HSW's Avatar
you should upgrade to the racetronix fuel pump kit.
Old Feb 24, 2009 | 08:22 AM
chris23120's Avatar
sounds like it
Old Feb 24, 2009 | 08:00 PM
V10GTS's Avatar
fp safety switch.
