Need a lil covert info
Old Feb 21, 2009 | 07:23 PM
djsanchez2's Avatar
Default Need a lil covert info
Hey fellas,
I have decided against the top shot as a back-up, and have thought of another idea. Would it be possible to tap the rear of the block on a motor that will not be using the knock sensors? I will also be shaving the knock sensor tubes to free up room inside the valley.
I know the Cam and crank sensors are in the back portion of the block, but is there anyway to avoid them? I had something similar to this in mind:
into this:
With these nozzles/tubes going through the sides of the valley up under the intake ports, between the block and the lifter cups.
Old Feb 22, 2009 | 12:28 AM
383lt1impala's Avatar
I think nitro daves can transform a ls6 intake with the solenoids and all that stuff inside. I saw something similar not too long ago.
Old Feb 22, 2009 | 12:48 AM
djsanchez2's Avatar
Yeah mine will be carbed though, so that ideas a no go sir, And it is called the money maker manifold. He can make it out of a LT1, LS1, LS6, FAST, and truck manifold
I will be using a plate unit as my primary unit, but have been playing with the idea of a hidden secorndary unit to put on a progressive so it's nearly undetectable.
