nitrous question
Old Mar 10, 2009 | 04:42 PM
ls1_sw's Avatar
Default nitrous question
ok i have a question........i was running a dry 75 shot and i went 11.9 on a stock motor now i have installed a wet system with a 125shot i had the bottle pressure about 950psi i sprayed it in 3rd on the high way it kinda bogged so i let off i tried it again and it bogged again but i didnt let off the botton and it kicked it but i could barely feel it its an nos system and the fuel pill is a 55 should i drop the fuel to like a 50 ???? any help is appreciated than you...
i also just finishd installign an ms3 cam so duno if it will make a diff now that i have a cam in
Old Mar 10, 2009 | 04:50 PM
jetlag's Avatar
There is no possible way to know the exact jet your car needs unless you have a wideband.
Old Mar 10, 2009 | 05:36 PM
ls1_sw's Avatar
well im going to get my car tuned on friday for motor and for nitrous now that i have the hp tuner i will keep both tunes on there so hopfully iwill no by then
