blow down tube?
Old Mar 17, 2009 | 06:12 AM
z28rob18's Avatar
Default blow down tube?
i want to mount the bottle right above the gas tank inside the car if i had the blow down tube go right dow would it be safe if the valve opened and emptied nitrous right above the gas tank? sorry if this is dumb
Old Mar 17, 2009 | 08:07 AM
nahasapeemapetalon's Avatar
Yes. I see no problem with that, all it would do is make things cold. N2O is not flammible.
Just dont drill into anything under there!
Old Mar 17, 2009 | 11:32 PM
JoeyGC5's Avatar
Just make sure you won't be spraying the blowdown tube directly on any rubber hose, plastic connection (ie hose barb), or and electrical connector.
Old Mar 18, 2009 | 12:52 PM
LSXFORMULA99's Avatar
it would be fine, I have seen alot off ppl do it
