200 wet shot?
Old Mar 20, 2009 | 12:56 PM
blackls1ta00's Avatar
Default 200 wet shot?
should i need a nitrous filter or use stock gm piece spraying a 200 wet shot,i have a racetronix kit with hot wire and 42lb injectors?
Old Mar 23, 2009 | 11:57 PM
Nitro Dave's Nitrous Outlet's Avatar
I am kind of confused by the question. Yes to the nitrous filter.
Here is a good one that you can take apart to clean.
http://www.nitrousoutlet.com/catalog...roduct_id=2765
Old Mar 24, 2009 | 09:51 AM
Nick@HSW's Avatar
I like this filter kit as well. Has the option of using a -6 line into the filter to avoid any feed issues with smaller lines. Also completely cleanable. If you don't already have any other accessories, I would recommend taking a look at our all-out kit. It features everything you would ever need for safety and consistency.
Still run the stock filter for the fuel side as well.
Nick
