need help with buying the safest set up.
Old Mar 24, 2009 | 01:47 PM
ALEXZ28's Avatar
Default need help with buying the safest set up.
i want to run nitrous, what all do i have to do b4 i buy the nitrous kit? i have full boltons.
Old Mar 24, 2009 | 01:51 PM
Mike@HSW's Avatar
depends on what size shot you want to run and what your current fuel provisions are.
Old Mar 26, 2009 | 09:35 AM
ALEXZ28's Avatar
i want to run a 75 wet shot.
Old Mar 26, 2009 | 08:57 PM
Nitro Dave's Nitrous Outlet's Avatar
On the stock bottom end you can spray up to 150 shot. Reading your mod list your motor appears to be completely stock so I am assuming you still have stock tumming as well. If I am correct you can spray up to 150 with out pulling timming. Anything over a 100 shot you need to concider upgrading the fuel pump. Make sure to change your spark plugs to a NGK TR6.
Let me know if you have any questions.
Thanks
Dave
Old Mar 26, 2009 | 09:16 PM
jmill96Z's Avatar
Has the car been tuned for the mods that are on it right now? You really need to know how much timing is in it before you hit it with the spray. You might not need to take any out, but why chance it?
