View Poll Results: how big of a shot
100 shot till you get bored
10
58.82%
150 shot ..go big or go home
7
41.18%
Voters: 17. You may not vote on this poll
how much spray??
Old Mar 24, 2009 | 11:06 PM
dandrea86's Avatar
Default how much spray??
I just bought nitrous plate for my car..This will be my first nitrous car. I just wanted to get everybodies opnion on how big of a shot. Should I just run 100 shot for now and get dyno tune. Then up it to a 150 in time. Or should I just go big now and spray 150.
Old Mar 24, 2009 | 11:15 PM
01SuperSport's Avatar
I think that you should start with the 100 shot just to see how your cars reacts to it. As soon as you get a handle on how to control the car then move up. I'm saying just so that you don't spin out and wreck.
Old Mar 24, 2009 | 11:27 PM
tording99Z28's Avatar
Are you going wet shot or dry shot? I would start out with the 100 and see how it responds. A dynotune will always be the best way but usually with 150 or less size shot you will be fine assuming you have all the sufficient fuel items to support the shot(injectors, pump, etc)
I spray a 150 shot on mine and I just simply retard my timing 5 degree's and I have had zero issues. I spray a wet shot and I have also upgraded my fuel pump to support the need for more fuel in the rails.
Old Mar 24, 2009 | 11:39 PM
waterbug1999's Avatar
start small and work your way up... you are a noowbie still.
Old Mar 25, 2009 | 06:54 AM
dandrea86's Avatar
its a nitrous outlet plate.. Im deff gonna get it dyno tuned with either shot I go with. I was leaning towards going with the 100 shot for now and seeing wut kind of numbers I can put up at the track.
Old Mar 25, 2009 | 09:25 AM
Nick@HSW's Avatar
I agree, start out small and work your way up. Its just a jet change away.
Nick
Old Mar 25, 2009 | 02:09 PM
LM97Z's Avatar
Like said, start off small, you would be surprized what a 100 shot will do when tuned right, don't start throwing jets at it, thats how stuff goes kaboom!! I'm running 100 shot & i've dropped a solid 1.3 & over 10 MPH on my ****.
Old Mar 27, 2009 | 08:20 PM
SStriker's Avatar
I say start with the 100 shot and then 125 when you get use to the 100...Then after that step up to the 150...
Old Mar 27, 2009 | 09:08 PM
dnkynrbk's Avatar
START small and work your way up. Dont forget to get colder plugs and take out timming. Talk to a sponsor if you need help.
Old Mar 29, 2009 | 10:23 AM
TARZAN's Avatar
Its always best to start small and work your way up
-Will
Old Mar 29, 2009 | 11:32 AM
coxta's Avatar
either way make sure you change your plugs and get it dyno tuned so they can pull some timeing
