TPS switch and Mallory window???
Old Oct 22, 2003 | 10:26 AM
VT_01_SS_ls6's Avatar
Default TPS switch and Mallory window???
hey guys im doing an install of a TNT F-2 kit on my car and was wondering if, the TPS switch has to be wired in too??? will the window switch be enough as long as i have it WOT when it hits @ 3500 ???? is this safe?? i have a Mallory window switch . also what should i gap my TR55's @ ??? i have some TR6's too .. what are those gapped at???
thanks
Old Oct 22, 2003 | 11:43 AM
brut28481's Avatar
Default Re: TPS switch and Mallory window???
I am not sure what tps switch you are using but I had the nx tps switch and its was junk. There is a little set screw that adjust what voltage the switch triggers the relay and after you would set it it would move out of adjustmnet and not work. Then it died all together. Had it for maybe a week before I junked it. just my 2 cents.
