Help with TPS and RPM/Tach wires
Old Mar 28, 2009 | 07:06 PM
blakern's Avatar
Default Help with TPS and RPM/Tach wires
Hey guys im trying to wire my dynotune window switch and I need to locate the TPS wire and the RPM/tach wire. I searched it out and came up with (the Dark blue wire, at PCM pin number 12) for the TPS. But what about the RPM wire? I think its suspose to be white.
Remember my cars a 98.
Thanks..
Old Mar 28, 2009 | 09:44 PM
Beer99C5's Avatar
http://www.ls2.com/boggs/torques/98pinpcm.htm
98 Pinouts.
Old Mar 28, 2009 | 10:53 PM
blakern's Avatar
thanks man..
looks like pin 12 and pin 35.
Old Mar 31, 2009 | 07:50 AM
miller456's Avatar
Originally Posted by blakern
thanks man..
I just wired my nitrous outlet rpm box up this weekend and I also have a 98. Good thing is I already had my pcm tapped for the rpm awhile ago from installing my shift light. You do have the correct pins though. Install university has a write up on installing a shift light which shows the pin for a 98 for the tach and 35 is the one you want. The tps was pretty easy to follow in the harness for me as well, good luck man.
