stupid nitrous newbie question.
Old Mar 29, 2009 | 04:30 PM
redtail2426's Avatar
Default stupid nitrous newbie question.
I am working on my old car 88 transam with a 383 stroker/modified lt1 intake.We are installing a direct port nitrous system from NX.I want to know where i get the fuel from.Do i just tap into the schrader valve??And do most nitrous kits come with the hose to go from the valve to the nx fuel rails.any help would be great thanks
Old Mar 29, 2009 | 05:25 PM
TARZAN's Avatar
You *can* come off the schrader valve (make sure you remove the valve stem).....but if you've got a built engine with a direct port, I would advise using a dedicated fuel system for the nitrous.
-Will
Old Mar 29, 2009 | 06:19 PM
Ls1Gummi's Avatar
^^^ what he just said.
Old Mar 29, 2009 | 08:36 PM
do you think we need a dedicated fuel system with only a 100 shot.thanks
Old Mar 29, 2009 | 09:56 PM
TARZAN's Avatar
I don't think you should waste your $$$$on a direct port if all you plan to spray is a 100 . A single nozzle could do that just fine, and save a pile of $$$$.
But to answer your question, an in tank 255 pump, with good wiring (to provide proper power) should be ok for the engine and a 100 shot. I would still have a wideband gauge on the car when you spray it, to ensure that you don't go horribly lean. A fuel pressure safety switch would be a nice addition as well.
-Will
Old Mar 30, 2009 | 05:27 AM
sweet thanks you for the answers.he wants the direct port for his next car/engine combo really.For this 383 all he plans on hitting it with is the 100 because any more may be trouble.He has the walbro in tank/a wideband/and the fuel pressure ss,so it seems we are in good shape.You have been a great help thanks
