how to mount a WOT switch
Old Mar 30, 2009 | 02:49 PM
wantmore's Avatar
Default how to mount a WOT switch
I have a basic but very safe NX kit Im installing and I have an issue on how to mount the WOT switch. Does anybody have pictures of how they mounted theirs? because right now im kind of stuck. Any ideas? Thanks
Old Mar 30, 2009 | 04:23 PM
transam69230's Avatar
Couple of ways to do it. You can mount it under the gas pedal. Pull back the carpet and there is a bolt down by the pedal to mount it to. You bend it the bracket the so that when the gas pedal is at WOT it clicks turnning the noids on and spraying. The other way is to mount up by your throttle body. Same idea as the gas pedal, you need to make it so that when the throttle is wide open it hits the WOT switch and activates the the nitrous. Really though just by a TPS module its a lot easier to wire up and to deal with if you ask me.
