NXL and LS1 edit question
Old Oct 23, 2003 | 09:46 AM
93LS1RX7's Avatar
Default NXL and LS1 edit question
Hey guys I am finishing up my NXL install and want to give her a run the next few days. I know I need to get some TR6's but what do I need to do in edit to get her to run safely.
I know I need to retard but how much. It will probably be a 100-150 shot.
Anything else in programming or even just nitrous based.
Sorry if this should be in the PCM forum it has a split personality.
Mike
Old Oct 23, 2003 | 10:18 AM
JF WS6's Avatar
Default Re: NXL and LS1 edit question
TTT I'm wondering about this as well. I was thinking of getting the timing tuner from Ramchargers that allows you to retard timing on N20 runs. I don't want to sacrifice the NA performance for the nitrous so that seems like a good way to do it and be able to switch timing settings.
Old Oct 23, 2003 | 05:09 PM
Fast SS on TNT's Avatar
I'm doing exactly that. I have a timing tuner that activated when the nitrous system is activated.
My best guess is for you to retard it about 2-3 degrees for safety. If you have ATAP, and YOU SHOULD HAVE IT!!!! Watch the knock, and fuel ratio like a hawk!!!
