Would #36lb injectors be enough?
Old Apr 9, 2009 | 06:12 PM
whytryz28's Avatar
Default Would #36lb injectors be enough?
Gonna be spraying a 100 wet shot on my LT1, will 36lb injectors be enough? Gonna have to send the chip out to be re-tuned i know for the nitrous.
Also what brand do you recommend?
Old Apr 9, 2009 | 06:17 PM
spaz1's Avatar
If your running a wet shot your injectors have nothing to do with it and you probably don't need a new chip with a 100 shot. If you are worried about timing and want to pull some you could use a resistor with the Iat and the pcm will pull some timing.
Old Apr 9, 2009 | 06:43 PM
01_ram-air's Avatar
Yup. don't have to worry about injectors when you're going wet. I wouldn't even worry about the timing on the 100 shot.
Old Apr 9, 2009 | 06:57 PM
whytryz28's Avatar
No **** huh...Thanks guys.
What about the fuel pump? Should i opt for an aftermarket one or stock will be fine? Ill have a pressure gauge and all that to monitor the motor and FPSS maybe a window switch.
Old Apr 10, 2009 | 03:57 PM
98transamtx's Avatar
dnt worry bout it! just change the plugs to ngk tr6's and ur set!
