Installing Nitrous from Nitro Daves have two questions
The wires I tie into on left side of motor RPM censor wire is blue, and bottom TB censor wire is blue correct? The wires your talking about are attached to the window switch.
Any size stereo fuse type will do?
The RPM wire will tap into the coil pack harness on the passenger side. It is usually a pale green and the second wire from the right.
Yes, the dark blue wire on the TPS sensor is the one you need to tap.
