Questions OPINIONS
I heard I should pull a plug or two after my first spray to check for detenation?
Also can I pull out my nozzle and set the window switch to like 500RPM's and hit the WOT switch to see if its spraying?
Pulling a plug is never a bad idea. Just remember it should be pulled after a wot run and you really shouldn't allow the plug to see much, if any idle time prior to pulling them.
Which window switch are you running?
Nick
