will this feed my setup?
Old Apr 16, 2009 | 08:46 PM
RARON455's Avatar
Default will this feed my setup?
I am almost ready for the swap, and not too sure if my fuel pump will get teh job done. I am using a zex wet kit right now on my motor with a 260 LPh pump and the stock injectors. and have had no problems on the spray.
I am swapping my heads PRC 5.3 stage 2.5, cam custom ground for the spray, ported fast 92intake and TB, and am going to up the spray to a 175 shot. My question is this, Will 42lb injectors be enough, and will the single 260 pump carry the load, or will I have to add another fuel pump to supplement the fuel supply? If I have to add more, any reasonable suggestions, any help will be appreciated thanks fellas.
Old Apr 17, 2009 | 09:16 AM
Nick@HSW's Avatar
Your injectors will only be required to keep up with the N/A hp. Is there a hotwire kit for the fuel pump? If not I would suggest investing in one. Anything else let me know.
Nick
