i got some nitrous questions
i want to run the first stage on a WOT switch and when that one hits activate a progressive controller to add my second shot i want to run my first stage at 100hp and have my second be 100-150hp is there one controller that could do this? as of now here is my parts list
2x dynotune 8cyl EFI nitrous kits
1x harris speed works micro edge controller
1x nitrous outlet progressive controller
1x dynotune purge kit
i was thinking i could run the micro edge into the progressive controller to activate my progressive hit is this possible?
and i planned on running both of the kits trough efi nozzles until i could get a nitrous outlet dual stage plate is this gonna be a problem?
what psi do stand alone fuel systems need to be at?
what psi does a stand alone fuel system operate at?
1x 1gal jegs fuel cell
1x areomotive fuel pressure regulator
1x aeromotive fitting kit
1x MSD 43GPH @ 40psi fuel pump
1x summit -6an fuel filter
1x summit race fuel pump w/ regulator
1x summit -6an fuel filter 27
would run around $225
and now that you mention it would work i think im gonna run a low pressure system and use a tad bit bigger tank (4gal RCI tank to bring the total to $240)
