HELP!Problems with N20 Outlet dual stage WS
Old Apr 19, 2009 | 11:41 PM
WheelsUp84z's Avatar
Default HELP!Problems with N20 Outlet dual stage WS
i got my nitrous kit all hooked up, dynotune kit with nitrous outlet window switch and plate. i check all the wires and they are all good. the problem i'm having is that the nitrous will activate in only one gear, after i shift it stops working. If i go from a dig it will work in first, or if i'm rolling ins 2nd or 3rd it will work but then shut off when i shift. i've tried hooking up both stages from the controller independently and both at the same time but still get the same result. it works great in that one gear, turns on and off at the right rpms, but once i shift it wont come back on. Is there soemthing i'm missing? any help is appreciated. hopefully i dont have a faulty controller but thats what i'm narrowing it down to. i havent even gotten one bottle through it yet.
Old Apr 20, 2009 | 10:13 AM
Grant@NitroDaves's Avatar
LS1TECH Sponsor
Give us a call at the shop 866-648-7637, and we can go through your setup and settings.
