Can someone help me identify solenoids...
Old Apr 21, 2009 | 09:36 PM
04RedGTO's Avatar
Default Can someone help me identify solenoids...
I bought a used dry kit for my GTO. It is the halo kit with the halo bar for the stock air box. It also came with 2 solenoids, both of which look identical...one for the nitrous and the other for purge.
My problem is, the solenoid that was hooked up to the halo bar does not hold bottle pressure, but the one that was hooked up to the purge holds pressure fine. Now since both of these solenoids look identical, and have no distinguishing markings on them, would it be ok to just run the one that was used for purge on the halo bar, and for the time being go without a purge?
Attached are pics of the solenoids...they both look like this.
The solenoid has a white sticker with N2O Nitrous on it. The N and the O are purple, and the 2 and nitrous are black.
Attached Thumbnails Can someone help me identify solenoids...-img_3438.jpg   Can someone help me identify solenoids...-img_3439.jpg   Can someone help me identify solenoids...-img_3440.jpg   Can someone help me identify solenoids...-img_3441.jpg   Can someone help me identify solenoids...-img_3442.jpg
Old Apr 22, 2009 | 09:10 AM
Grant@NitroDaves's Avatar
LS1TECH Sponsor
That is one of our older solenoids. Is it that the nitrous solenoid wont open under pressure or it leaks. There could be some debris on the piston keeping it open enough for 1000 psi to squeak by. If you feel comfortable you can take it apart and inspect the piston for debris or excessive wear. If not, feel free to send it to us and we will inspect for free and let you know what needs to be done/replaced.
