rebuilding the noids...
Old Apr 22, 2009 | 09:46 PM
waterbug1999's Avatar
Default rebuilding the noids...
When should they get rebuilt and whats involved? Thanks.
Old Apr 22, 2009 | 09:59 PM
blakern's Avatar
I was told that they should be rebuilt if they have sit for awhile, like over winter and such. I think once a year would be enough, depending how often you spray. If your going threw a bottle a week, then maybe rebuild more often. When I went to rebuild mine I ordered replacement plungers from dynotune. Look for crud in the noid and seals that look bad.
Old Apr 22, 2009 | 10:02 PM
WE TODD DID's Avatar
Whenever you decide to freshen up the solenoids, be sure to use teflon plungers. They last a whole lot longer.
Old Apr 22, 2009 | 10:03 PM
I think this is going on the 3rd year for mine. The 1st year I ran ~40 bottles and last year I ran ~10 bottles. I have not sprayed yet this year.
The car sits in storage for the whole winter. How do you check/take them apart? How much are parts and what to replace?
I havent really looked at them to tell you the truth, I just dont want to take the nut off and crap come falling into my lap and saying, o'snap, hows this go back together sort-a thing.
Old Apr 22, 2009 | 10:12 PM
blakern's Avatar
naw. its not that complicated.
I think the replacment plungers for mine were $15.
Old Apr 22, 2009 | 10:15 PM
How can a plunger go bad? Im assuming just leaking right?
Old Apr 22, 2009 | 10:16 PM
blakern's Avatar
These are the replacment plungers I ordered, of coruse I went with dynotune products, but im sure what ever kit your running offers them to.
http://www.dynotunenitrous.com/store...?idproduct=142
Heres some instructions for rebuilding dynotune noids, should be about the same as all other noids.
http://www.dynotunenitrous.com/store...D%20REPAIR.pdf
Old Apr 22, 2009 | 10:19 PM
blakern's Avatar
Well I thinjk basically crud can get in them over time and then they can stick. Also the seals can become misshapened over time because of pressure and then cause problems.
Old Apr 22, 2009 | 10:28 PM
Thanks for the links, I have NX so I guess ill have to get it thru them...
I would assume that the seals would go out alot more then the plunger though.
Old Apr 22, 2009 | 10:34 PM
Im looking at Nitro Daves website (thats where I bought my kit) and I found the NX parts, is it 52 bucks for the damn plunger (I guess they call it a piston)?
NX Solenoid Replacement Parts
Part Number Description Price
NX-15738 PISTON ONLY, ( FUEL SMALL .125 ) $ 52.00
NX-15739 PISTON ONLY, ( FUEL .187 ) $ 52.00
NX-15740 PISTON ONLY, ( FUEL .312 ) $ 52.00
NX-15741 PISTON ONLY, ( NITROUS SMALL .063 ) $ 52.00
NX-15742 PISTON ONLY, ( NITROUS .093 & .125 & LARGE .063) $ 52.00
NX-15743 ELECTRO-MAGNET ONLY ( NITROUS .093 & .125 & LAR... $ 52.00
NX-15744 TOWER ONLY, (NITROUS .093 & .125 & LARGE .063) $ 52.00
NX-15745 TOWER GASKET (NITROUS .093 & .125 & LARGE .063) $ 5.00
NX-15746 ELECTRO-MAGNET ONLY ( NITROUS SMALL .063) $ 52.00
NX-15747 ELECTRO-MAGNET ONLY ( NITROUS SUPER SHARK .157) $ 79.00
NX-15748 ELECTRO-MAGNET ONLY ( FUEL .125) SMALL FUEL $ 52.00
NX-15749 ELECTRO-MAGNET ONLY ( FUEL .187) $ 52.00
NX-15750 ELECTRO-MAGNET ONLY ( FUEL .312) $ 52.00
NX-15751 SOLENOID TOWER ONLY, (NITROUS SMALL .063) $ 52.00
NX-15752 TOWER ONLY, (NITROUS SUPERSHARK .157) $ 79.00
NX-15753 TOWER ONLY, ( FUEL SMALL .125) $ 52.00
NX-15754 TOWER ONLY, (FUEL .187) $ 52.00
NX-15755 TOWER ONLY, (FUEL .312) $ 52.00
NX-15756 TOWER GASKET (NITROUS SMALL .063) $ 5.00
NX-15757 TOWER GASKET (NITROUS SUPERSHARK .157) $ 5.00
NX-15758 TOWER GASKET (FUEL SMALL .125) $ 5.00
NX-15759 TOWER GASKET (FUEL .187) $ 5.00
NX-15760 TOWER GASKET (FUEL .312) $ 5.00
NX-15761 PISTON ONLY, ( NITROUS SUPERSHARK .157 ) $ 75.00
http://www.nitrousoutlet.com/catalog...del=90&dept=11
blakern's Avatar
Yeah your prob right. But if your trying to decide weather or not your plungers and springs need replaced I'd just go ahead and replace them. Its prob cheep insurance. Sometimes things dont go so well when/if they fail.
Old Apr 22, 2009 | 10:37 PM
blakern's Avatar
wow that suxs. I'd call or PM one of the nitrous outlet guys and see what they recommend.
Old Apr 22, 2009 | 10:41 PM
I just cant believe its that much.. If they are, then I guess ill just clean them and replace the seal/o-ring.
Old Apr 22, 2009 | 10:43 PM
The plunger is what goes bad.
Old Apr 22, 2009 | 10:45 PM
blakern's Avatar
I guess your noids must be "better" than mine, cause I can replace a whole noid for $59.
Old Apr 22, 2009 | 10:51 PM
Is that what they have labeled as the piston in post #10?
How would it go bad?
Old Apr 23, 2009 | 09:31 AM
Nick@HSW's Avatar
Swelling, cutting, debris, tolerances...lots can happen to a plunger over the course of time. The amount of lift coming off the base of the solenoid is not as much as some people assume it is and minor variances within the plunger can alter flow characteristics, sealing, etc.
Nick
Old Apr 23, 2009 | 11:57 AM
Nick
So, this will result into leaking?
Old Apr 23, 2009 | 01:55 PM
Nick@HSW's Avatar
It can. It can also impede flow through the solenoid as well.
Nick
Old Apr 23, 2009 | 04:47 PM
Nick
Well, I see your noids ar ~$60 bucks for a bran new one... And, the NX ones are $57 for a plunger and o-ring. WTF are NX's so damn expensive? Can I use other then NX parts?
Do the fuel and N20 noids open the same distance? I am temted to just verify that to make sure they are equal and check for leaks and call it a day..
