150 shot ?
Old Apr 25, 2009 | 06:12 PM
TravisMcGill2000's Avatar
Default 150 shot ?
i have a bolton lt1 and i been spraying 125 shot. can i bump up to a 150 with out hurting anything. its on stock timing and if so should i mix alittle race gas in with it to be safer.. thanks guys
Old Apr 25, 2009 | 06:13 PM
ssick1's Avatar
should be okay
Old Apr 25, 2009 | 06:15 PM
you think i should mix some race gas or just run 93
Old Apr 25, 2009 | 06:45 PM
Z-RATED94's Avatar
I would at least put some race gas in it. How are your plugs, and are you using TR6s?
Old Apr 25, 2009 | 07:04 PM
yea im tr6s and there about 6mths old
Old Apr 25, 2009 | 07:11 PM
Z-RATED94's Avatar
Depending on the condition of the motor, you might want to throw a fresh set in. And not to be a downer but I pull 5 degrees with a 130 shot on the factory set WOT timing. Maybe I'm just a little paranoid?
Old Apr 25, 2009 | 07:24 PM
k thanks guys.. i lte yall know wat happened tomorrow
