stumbling after plug change
Old Apr 26, 2009 | 01:30 PM
z28_YOU_HO's Avatar
Default stumbling after plug change
I switched over to the NGK TR6 plugs and at idle it seems to run a little ruff. Kinda sounds like it misses a little bit. Once i get on the gas though its smooth and doesnt have any problems. Any ideas??
I checked the gap on all the plugs before installation
Old Apr 26, 2009 | 01:50 PM
Braciole's Avatar
Definately sounds like a gap issue. Check all the plug wires make sure they are on correctly.
Old Apr 26, 2009 | 02:15 PM
z28_YOU_HO's Avatar
Yeah I checked all the gaps TWICE before I installed them. Pretty sure all the wires are on correctly because like I said it runs fine when on the throttle.
I dunno ill have to pull the plugs and check um. Damn not looking to pull demon # 8 again
Old Apr 26, 2009 | 03:09 PM
WE TODD DID's Avatar
Might have cracked a plug.
Old Apr 26, 2009 | 03:16 PM
bigftruck's Avatar
could have pulled a wire in 2 internally when u pulled them off
Old Apr 28, 2009 | 11:31 AM
QWIKWS6's Avatar
My car ran the same way when I put the TR6 in and I checked everything multiple times and thats just the way they are.
Old Apr 28, 2009 | 01:46 PM
ShiznityZ28's Avatar
What is the "perfect gap" ?
Old May 10, 2009 | 12:57 AM
Braciole's Avatar
I would love to hear the answer to this, Im sure it will vary with opinion.
Old May 10, 2009 | 08:40 PM
Mike@HSW's Avatar
Whatever their gapped at in the box, if its not perfect its ngk's fault lol.
Old May 11, 2009 | 01:19 AM
M-ManLA's Avatar
Gap needs to be a 0.06. Some NGK's come as a 0.059, which is fine.
