How much n.o.s will my current fuel system take?
Old Apr 26, 2009 | 01:44 PM
mike c.'s Avatar
Default How much n.o.s will my current fuel system take?
I have a 402ci making 520hp n/a. I have a walbro 255 pump w/hot wire kit and 38lbs injectors. I have a timing tunner to retard when the n.o.s comes on. How much can this fuel system take? I would like to hit a 150 shot and I have a T.N.T wet kit. This should put me 650 rwhp and will check it on the dyno to be safe. Thanks. Mike c.
Old Apr 27, 2009 | 03:49 AM
deuce_454's Avatar
i wouldnt put it past that walbro to supply both a 520 Hp and a 150 hit.... for your own piece of mind, install a dedicated fuel system for the wet kit.... it is always cheaper to do things right the first time.......
Old Apr 27, 2009 | 06:49 AM
dnkynrbk's Avatar
I agree talk to on of the Nitrous tech sponsors and ask them. Do you have HP tunners to check your injector duty cycle?
Old Apr 27, 2009 | 11:07 AM
Chris@NitroDaves
Guest
Posts: n/a
We have typically seen the Racetronix style systems support around the 650-680rwhp mark. In theory you should be ok but if wanted to be 100% sure then i'd put a dedicated on it abd that would cover you for fueling now and if you decided to step it up later.
-Chris
Old Apr 27, 2009 | 05:07 PM
mike c.'s Avatar
I'm spending another 2k on my car and didn't want to spend another $700+ on a fuel system. I will spray less if I need to. Just wondering what my fuel system could handle. This all will be checked by my tuner on the dyno to be safe. Thanks.
