15 lbs nitrous bottle goes quick!
Old Apr 27, 2009 | 01:59 PM
jester ls1's Avatar
Default 15 lbs nitrous bottle goes quick!
I am running the 125 HP jet and the car loves the bottle. How many passes should I see with the bottle full? Also when the nitrous runs out and you just have cold air the car still pulls pritty good should I just keep running untill the air pressure is completely gone?
Nitrous is addicting
Old Apr 27, 2009 | 02:05 PM
ElkySS's Avatar
im not aware that you should have any air in the nitrous bottle at all. it should be totaly nitrous and nothing else.
Old Apr 27, 2009 | 02:08 PM
jester ls1's Avatar
You see white nitrous for about 15 runs then just air.
Old Apr 29, 2009 | 08:45 AM
2nd3rd4thgen's Avatar
im no expert but i do know that you dont need to run your bottle till its empty if thats what you are asking
Old May 4, 2009 | 08:18 PM
THE LAST Z's Avatar
You could, but i dont see why. I wouldent spray until its empty & keep driving around. You dont want to be with an empty bottle when you really need it
Old May 5, 2009 | 11:45 PM
02_ramair_ta's Avatar
What your saying is confusing...
Your heating your bottle, right?
What kinda kit are you running?
are you running a Nano kit?
Old May 6, 2009 | 11:25 AM
landonew's Avatar
Once the nitrous bottle drops below a certain pressure, you will no longer have a 125 shot.
It will turn into a 100 shot, then a 75 shot, and then eventually a 0 shot.
The nozzle is rated for 125hp @ 800-1000psi..... If your bottle is almost empty and thus at 200 psi, then you are not getting a full hit.
Most people who use a bottle heater to regulate pressure re-fill their bottle when they can no longer heat it up to get 800 psi. Some wait till 600 psi, and others wait longer.
I have a nano kit, so I get every once of nitrous out of my bottle.
Hope that helps.
