Nitrous Outlet Window Switch....need help hooking it up
Old May 2, 2009 | 09:49 AM
DopdBrd's Avatar
Default Nitrous Outlet Window Switch....need help hooking it up
Ok, so I am trying to get my nitrous kit wired before tonight. I have a wiring diagram that I am working off of. And on the diagram, it is set up for a Mallory 685 Window Switch. Well I am not using this and using the nitro daves switch. On my diagram, it has the purple wire acting as the ground for the Fuel/Nitrous relay, which would be terminal 86. Now, when I look at the Nitro Daves wiring diagram, it is using terminal 85 for the yellow wire that goes to the Window Switch.
Can I just plug the yellow wire from the Window switch into terminal 86 and will that work?
Old May 2, 2009 | 10:42 AM
Beer99C5's Avatar
86 power from Switch
85 Yellow from Window Switch
87 is relay to Noid
30 is power souce Switched (for 25-20 amps)
Window Switch
Blue TPS or Mech WOT switch (be sure to program correctly)
Green to Tach wire or Coil pack (program correctly)
Old Jun 23, 2011 | 03:38 PM
6.0 silverado's Avatar
I know this is an old thread, but...
I have the Nitrous outlet dual stage rpm window switch. I don't think the box is reading the rpm's correctly. When I hold down switch #1, it displays odd rpm values that jump around.
I tapped the white wire (pin 10) on the pcm and connected it to the green wire on the box. I programed the box to 004 on the tach set-up step and I getting these odd rpm values.
Any help would be greatly appreciated.
Old Jun 27, 2011 | 10:31 AM
How did everyone else that has this box hook theirs up?
Old Jun 27, 2011 | 10:42 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Hey sir,
If you are having any problems, give us a shout and talk with Chris on this deal. He is a pro at getting the window switches all lined out.
