Stand Alone
Old May 7, 2009 | 06:14 PM
02 BLK WS6's Avatar
Default Stand Alone
I put together a stand alone system and thought I'd share a few pics. This is a 100% new system for a little more than $400 with shipping. This is a high pressure system. A low pressure system could be put together for $50-$75 less.
Old May 7, 2009 | 06:24 PM
LS1SpeedAddict's Avatar
Where did you get the cell from? This is exactly what I need
Old May 7, 2009 | 06:34 PM
waterbug1999's Avatar
How is it mounted?
Here is the one I am alomst done with. It looks like we got the same cell, but I had them not weld any of the -8 bungs in, I just used bulkhead fittings and -4.
Old May 7, 2009 | 06:43 PM
02 BLK WS6's Avatar
I ordered everything through summit. I cut the mounting tabs off and it is strapped into place. RCI doesn't recommend using the tabs for anything more than mock up. I kept all of the lines big with reducers for future growth... -6an feed, -8an return.
Old May 7, 2009 | 06:48 PM
They said that?
I welded two nuts in the front cross member and bolted it down, its sturdy as hell.
Still looks nice either way.. You test it out?
Old May 7, 2009 | 11:41 PM
02 BLK WS6's Avatar
Originally Posted by waterbug1999
They said that?
There was a tag on the tabs that said not to be used for mounting and can cause failure of the cell. I have only pressure tested it and haven't tried it at the track yet. I hope to soon. I have converterted to true duals and instead of mufflers will be using inserts. They are backordered through Jegs so I clled the manufacturer and ordered a second set and am waiting for either set so I can finish my exhaust. 2 1/2' of 3in. pipe off the headers is too loud for street driving imo.
Old May 8, 2009 | 12:08 AM
Yea, you might **** people off. lol
I find it hard to believe that they will go thru the effort of welding 4 brackets on to it, then tell you not to use them. Doesnt make any sense.. Anyhow, still looks good, ill get out of your thread.
Old May 8, 2009 | 08:11 AM
z28rob18's Avatar
looks good sounds lik wat i need $400 instead of $700. do you hav a list of parts? if you do and could pm me them or post them id appriciate it. and maybe a little info on how you set it up.
Old May 8, 2009 | 11:35 AM
mattl31's Avatar
Also interested in a parts list. This is exactly what i need!
Old May 9, 2009 | 08:09 AM
fastGBcamaro's Avatar
X3. The standalones that Harris Speed & The Nitrous Outlet sell are really nice, but for $700 I will make my own. I might end up relocating the battery and use that space. It seems like it would be easier to fit the cell where the battery is.
Old May 9, 2009 | 10:50 AM
2001z's Avatar
Looks good!. I have a nitrous outlet one but really wish i would have just made my own and saved the cash and trouble. Hardest part looks like mounting the pump or welding in some bungs.
Old May 9, 2009 | 11:27 AM
Im using a stock pump that was free from a buddy of mine to keep the cost down. It should work fine.
Old May 9, 2009 | 05:14 PM
exactly what I'm thinking
Old May 9, 2009 | 10:47 PM
well, my **** is done.. Finally!!
Old May 11, 2009 | 02:49 PM
4U2NV-SS's Avatar
How did you mount your stock pump in you cell???
Old May 11, 2009 | 04:38 PM
Its just hooked to the hose and attached it to the -4 bulkhead. There is foam that comes with the fuel cell, I used that to keep it in place.
Also, if you use your stock pump you have to cap that little brass barbed fitting that sticks out.
Old May 11, 2009 | 05:57 PM
nastychevelle's Avatar
haha let me know when your gong down to GIR i wanna go watch ya get some runs in
Old May 11, 2009 | 05:59 PM
LS1BLKSS's Avatar
Banned Village Idiot
looks great man!!!
Old May 12, 2009 | 12:52 PM
4U2NV-SS's Avatar
I like to get a couple more pictures of your setup!
Sorry to hi-jack
Old May 12, 2009 | 01:55 PM
Sorry to hi-jack
There is really not much more to it... You cant see/take a pic of the inside.
