No Jets On 5177 Nos
Old Nov 2, 2003 | 08:19 AM
4thGENRETARD's Avatar
Question No Jets On 5177 Nos
What Would The Kit Shoot With No Jets? #36 Is About 85rwhp, #38 Is About 100rwhp.
Can We Do This Safely Or Are Jets A Necessity.
I've Seen Posts Where People Actualy Do That.the Kit Comes With#36 Max, #38's Have To Be Bought Separate.
It Is A Dual Solinoid, Dual Line Setup.
Old Nov 2, 2003 | 08:55 AM
slow's Avatar
running them in series, (the noids) i beliee people claim it will do 150 hp no jets.
... jets are cheap. motors are not
without a fuel system upgrade, i would never even think of trying a no jets 5177 kit
Ryan
Old Nov 2, 2003 | 03:17 PM
But poeple are running 150 'wet' kits with no fuel mods! Do you mean to say the MAF cannot handle adding the right fuel? How about just an inline Booster pump in addition, would that be enough??
I have a GMAF BTW & an 80mm BBK TB.
Old Nov 2, 2003 | 03:43 PM
bad2000ss's Avatar
You can run 150 on a wet kit because you are relying on the pump to supply extra fuel to the fuel solenoid that is adding fuel to compensate for the N20. When you are shooting dry you are relying on the fuel pump and the fuel injectors. Stock fuel injectors may or may not be up to the task of adding the extra fuel, but the question is, do you want to gamble on that?
Old Nov 2, 2003 | 03:52 PM
Ahh Sooo. yeah i get it now. I,m doing 391rwhp N/A. so yeah, I'm sure the stock Inj. will not handle 550rwhp on N2O.
But out of curiosity how about an inline booster pump with (??? ) injectors.How big would be good?
Old Nov 3, 2003 | 11:38 AM
bad2000ss's Avatar
A lot of people are going with the 30lb ford SVO injectors. Apparently they flow equivelent to 36lb injectors on a LS1 motor. And if you were going with a pump, replace your in tank pump.
Old Nov 4, 2003 | 10:00 PM
B18B1LS1's Avatar
My open solenoid 5177 kit at ~1200 psi made almost 150 rwhp with a cut-out as my only mod. But if you are making 391 rwhp NA I would definately upgrade your pump and injectors.
Jeffrey
